with a 4 speed atuo a 3.42 gear is good but you can step up to a 3.73 gear but...again whats the car for? unless its out and out racing i wouldnt worry too much.
yeah the 3.42 is available for the 7.5. richmond gear makes them up to 4.56 for the 7.5.
http://www.richmondgear.com/07pdfs/RG9.pdf
there's the PDF page showing you all the gears they have. wll you have to do is determine your carrier. its series 2 or 3. i forgot which is which but you can just get another diff of the same carrier as the ring and pinion set you get and you should be fine.
BTW they have a culculator
http://www.richmondgear.com/101032.html
as long as you know what the final gear is and your tire height you can compare your current gear and whatever MPH you like and then compare it to the gears you are thinking of getting.
i personally will probably use a 3.08 or 3.23 gear since i dont have an overdrive. but i might get one one day.
Transmission 1st Gear 2nd Gear 3rd Gear 4th Gear OD
Turbo 350 2.52 1.52 1 N/A
Turbo 400 2.48 1.48 1 N/A
2004R 2.74 1.57 1 0.67
700R4 /4L60 3.06 1.63 1 0.7
4L80E 2.48 1.48 1 0.57
just in case anyone wanted to know their gearing for their automatic transmission.
with a 26 inch tire, 65 MPH, with an OD gear of .7 you'll run 2K RPM
with the same inputs but with a 3.73 gear you'll run 2200 RPM. doesnt sound like much but depending on your set up that extra 200 RPM can eat gas up quickly. but depending on your engine may be in the sweet spot for your torque curve, allowing you to mash the pedal and kick it down into 3rd and pass someone easily.
and for kicks i did it with a 4.11 gear and the RPM is still a relatively low 2400 RPM. the overdrives make much higher gears possible.
now lets consider the first gear and rear gear ratio...basically multiply the two numbers and you get another number. generally around a 9-10 is good for street use, 11 and above is more suited to race tracks. this is general rule of thumb, not a hard and fast rule though.
take mine for example, 2.31 gear and my 2.52 first gear= 5.82. wow thats horrible! but thats how they made the car, for gas sipping at cruising speeds. with just the addition of a 3.23 gear it changes dramatically, 8.13. that's a huge leap in performance but isnt a very wild gear. the RPMs go up quite a bit but its as far as i would go without an OD transmission, then easily i would go with a 3.42 gear at the minimum.
i run around 1900 RPM at 65 MPH with my current gear, with a 3.23: 2700. an OD is your best friend. but since my car rarely sees over 50 since we dont do highway driving with it, we'd see about 2100 RPM at 50 MPH or about 2K with a 3.08 gear.
i can go on day about gearing.
