They could have done better in the umph department. But considering GM held them to 307 cubes, that was what they had to work with. The 3.73s woke up the 307 a bit.
If EPA had no say, then use a modified HVAC housing to clear the 10.5 CR 455 valve covers properly. Give it a rear gear of 3.42, and use a TH400 behind the 455. No need to worry about fuel mileage, right? Factory 2.5" dual exhaust without cat(s). Would that necessitate raising the body off the frame a bit (not the best idea) or redesigning the footwells to clear a factory correct double hump crossmember for that TH400 to fit that dual exhaust.
I'd make sure that cowl scoop was redesigned to function and be useful against the base of the windshield.
Along with a much better suspension and lower that beech about 2" front and rear, with at least some wider tires than the 215s on maybe 15x9" wheels. They didn't have bigger diameter wheels from the factory back then, but they could have.
I know the Lightning Rods were the 80s H/O thing to have, but I'd have a dual gate for a shifter. When adjusted right, the Rods do fine, but if they're not, they can be a nightmare. With a dual gate, the only thing you need to do for adjustment is get the right geometry on the trans selector shaft lever.
