Not sure of the '78 to '81 non windshield antenna cars but '82 up car would need to have the finish work of drilling the hole on the inner panel of the cowl to allow the cable to pass through. Everything is marked for this.Any antenna NOT mounted on the fender would require bodywork to fix the hole. Might as well use it to properly install a non-power antenna setup.
Another option is to get a windshield antenna setup. You'd have to set it up like the older cars with the connector in the center of the cowl, etc., but it can be done. I've never liked them as they're not that great, IMO, but it's just an option.
The windshield.
And the cable.
