How does that work - it sucks more but consumes little?they didn't rate this one but it's one that racers use and it takes less hp to spin it but it does move alot of air...
How exactly can a person scientifically test the effects of a mechanical fan at the track when a person can barely run 2 of the same times at the track with 10 passes? You'd need to take at least 10 passes to get a control or average, then do the same with each fan, only to be +/- .** in the first place. At least that's how I see it.
That wouldn't be a consistent number, a 500 hp engine would not be affected at much as a 175 hp engine
Depends on how well your car is dialed in - I've run 7.14_ 8 passes in a row (1/8th)
I don't drag race but I heard for every 10 lbs you lose you gain 1/10 at the track. If that is correct I guess that means for the week before a race you eat according to the options you want to run in the car.....😀
The fan I referred to is made by Afco and is relatively new on the market so it is not the same as the stock GM one they tested back in 2000.
