Anyone know if c7 zo6 calipers fit the blazer hubs?
WolfSS
n00b
Apr 3, 2022
2
An option for spindles is to keep checking lkqonline.com. They mostly have 4WD spindles so keep an eye out for 2WD spindles since they go fast. Pricing is based on condition plus shipping.
JAMCAR223
1,855
5,500
Houston, TX.
johnnunez29 contact me when you're ready to purchase the spindles. I sell these all the time on this forum. (2) spindles, (2) backing plates, (2) brake hose brackets, (2) brake hose bracket bolts, (2) brake hose clips, (4) caliper mounting bolts, (6) hub mounting bolts. All parts cleaned on the wire wheel, and ready to install. $180 shipped to the lower 48 states. USPS Priority with a tracking#. PayPal Friends & Family OR Walmart to Walmart.
* You won't be able to use the backing plates because they will not clear the larger rotors, unless you bend the sh*t out of them. They won't look good.
johnnunez29
174
34
IMO: do the brakes and see how it works with your factory setup. Then if you need to, do the booster/MC from a B Body. Trust me, change everything at once and then go chasing why it doesn't work like you want.
makes sense. so just do the brakes and change the proportioning valve. any chance you have the link to the proportioning valve?
johnnunez29
174
34
pm'd
JAMCAR223
1,855
5,500
Houston, TX.
johnnunez29
174
34
I went with a B body dual diaphragm booster, IIRC it’s a 12 inch booster. You might need to swap your master cylinder around, I can’t remember but I used a right hand drive S10 master cylinder for the years when the ABS module was up near the master cylinder.
You can find spindles floating around on ebay but the ones I’ve seen are around $250-$275 and I doubt that includes shipping so that’ll possibly run you in the $350 range for those by the time you’re done. Unless you’re married to 15 inch wheels, I’d get a conversion kit from Fly n’ Bye considering how much brake components have gone up recently.
thanks called them severla times and was promised a quote each time.... still nothing. who else would sell the c6 zo6 upgrade for blazer spindles? thanks for the info too
UC645
954
2,679
Kittanning, Pa
Short of making your own brackets, I’m not aware of anyone else offering conversion parts for Blazer spindles.
ssn696
Living in the Past
Jul 19, 2009
5,448
6,450
Permanent Temporary
Check Kore 3 - they offer hybrid S/G brackets, but they may only be for the six-pot Brembos. I have the 4-pots, and will likely engineer my own.
64nailhead
Goat Herder
5,396
11,363
Upstate NY
I bought mine off from eBay.
johnnunez29
174
34
i will be calling kore today. another dumb question for ya, do you know what hubs i should be buying for these spindles? also should i be extending the lugs?
