Anubis said:G_Body_Enthusiast said:they're no different than other g-body brakes ive driven. like i said, i just think they're too soft. i like a firm pedal. stock g-bodies do not have a firm pedal in my opinion. so you dont think stock g-bodies have a mushy pedal, good for you. doesnt mean everyone else shares your opinion or if theirs differs from yours they're stupid and dont know how to work on brakes.
I've owned several G body cutlass' and have to agree with G body enthusiast....Most of them had too much pedal travel and a spongy feel. Some of them were low mileage cars. I'm interested in hearing more about your B body master swap...let us know what you come up with.
i think i have my mind set on a master cylinder and booster for an 89 caprice. its larger by 4.6 mm and 4mm respectively. that's an increase in diameter of about 19.2% and 11% or so over the stock unit (24mm and 36mm) to 28.6mm and 40mm which is quite a step up i think. i should be able to easily notice a difference when i swap the master and booster out. if i use the two piston caliper brakes from a blazer that use a 1" master that's 1.4mm larger than the g-body unit which i think would feel a little worse without swapping it out for something bigger. so i think i'm starting at the master/boost and working my way out. i have braided hoses instead of the regular hoses to help cut down on that spongy feeling a little bit. they swell less so the pedal should be a little firmer.
i'm sorta guessing since i dont know what the exact volume is for the calipers i have and the ones i want to use. i just know if i change the volume needed for the caliper the master should be changed to match the extra volume needed. i think i'm making a decent educated guess on this and i'll find out later if i'm right or wrong. i think i'll be happier with the increased pedal effort and the extra clamping force.
