Did someone say stepside bed?
That Sierra was the best vehicle I’ve ever owned, without question. TBI injection so simple you can fix it with screwdrivers, and read computer codes with a paper clip if necessary. Rode, drove, and had the turning radius of an aircraft carrier, but there wasn’t a flaw in these things anywhere.
That's kinda ironic, I had a 96 K1500 ECSB with a stepside and I hated it. It wasn't so much the model itself more than it was that particular truck. The stepside was too small to fit anything I needed inside of it, the AC didn't work, it had the third door in the rear and it didn't shut right and there is no adjustment in that door, the hinge is welded on both sides, it didn't have a limited slip, I had issues with the spider injectors, it left me stranded a couple times, once was an overheat, once was a blown brake line. I just didn't get along with that truck. I only had it maybe 7 or 8 months but I was glad to get rid of it when I did.
