Astro van steering shafts
1320John$$$
951
2,043
Pennsylvania
How long are they and what size spline count is the box end
I have a chevelle nova Camaro manual box on my car and want to get away from the rag joint
ostrich
311
313
Ontario, Canada
Took a quick measurement, The shafts are 21" long (end to end) collapsible to 15"
Should be 3/4"-26 spline for the box end. Took a couple of pics for you.
20,397
If you have the stock G body shaft now then the Astro shaft will fit on the box
1320John$$$
951
2,043
Pennsylvania
I had to make it work with the chevelle parts g body rag joint was bigger then the joint on the box that I used it’s kind of Frankenstein together And I had to collapse the shaft to get it to fit sorry for asking
20,397
Don't be sorry about asking. I have a Chrysler style Borgeson box so I had to get a knucle to fit the box and Astro shaft. The bottom of the Astero shaft is a 1" DD in case you need to modify the Astro shaft to fit.. Looking at your set up perhaps you can cut the shaft behind the rag joint and get a knuckle to fit the shaft and the spline.
