I am compiling a list for my 70 Cutlass S but similar will be needed for a G body. I plan on buying everything but the TKX this year. My 330 crank already has a pilot bushing installed. I will probably run the Holley dash for gauges and speedometer once the 5 spd is installed. Here is my list:
Speedmaster dual pattern flywheel
Used BOP bellhousing
Probably repo Chevelle pedals
Slave and master hydraulic clutch
Good street clutch
Offset shifter for bench with shift handle and ball
Back up light harness
A body 5 spd crossmember and mount
Custom driveshaft with yoke
A wide ratio TKX 26 spline GM transmission
Am I missing anything?
Good street clutch
