Chillin014 said:I understand. I appreciate the pic! Does that bolt going through it connect to the master cylinder rod somehow? I'd probably just modify my A/G body pedals since its possible I just dont have much of an idea of how the connection is intended to look.
Yes, the bolt in the middle is where the master rod attaches. Here's an installed pic:
pontiacgp said:You don't need to modify the clutch pedal. The rod for the master clutch connects to the pedal the same way and position as the linkage set up..
here's another link that i don't think has been posted yet in this thread...
http://www.monte-list.nu/tech/fivespeed.shtml
That link is in the garage scene site I've referenced a few times (in the pedals section). From what I have read, those who have used the 3rd gen F-body pedals have had to slightly move the pin for the master rod as it doesn't line up quite right.
If you are talking about an A-body pedal, it is completely different and won't work (without modification) due to the geometry.
