Chillin014 said:I wish I had seen this thread before I created mine. You can use the factory G body pedal assembly with a hydraulic set-up cant you?? I just found a set out of an El Camino and thought I was on the right track but it looks like my options are very limited if I use the mechanical linkage.
You can only use the stock g-body pedals with a mechanical linkage (unless you modify them to accept the master cylinder rod). The mechanical linkage will work with the 606 g-body bellhousing, or the 1983 Camaro bellhousing. Check the garage scene link above for more info.
