I'm having an issue with terrible belt squeal and I need some help getting this issue fixed. First off, the vehicle is set up for air conditioning but the compressor isn't on the car. With this being said, the alternator is on the drivers side above the power steering pump. I replaced both belts for the alternator and power steering but the squeal is still there and it's really loud.
I took the power steering pump off and removed the pulley to see if the pulley was bent but It looks straight. I laid it on a flat surface and it didn't wobble either.
I put the power steering pump back on and installed the belt back on and tightened it as it should be. I left the alternator belt off and started the vehicle. Same squeal. This leads me to believe that it isn't the alternator belt. I hand turned both the power steering pump and water pump and they feel fine.
Other than ensuring the belts are tight, what else could it be? Any help is appreciated!
