Backfire issues
Froggys86
231
55
California
Have a 81 el camino v6, replaced carburetor, vacuum lines, spark plug and wires, and did timing...it starts right up and drives good just that it backfires, could someone please.let .e know what it could be? Thanks in advance all and any replies is highly appreciated.
airboatgreg
2,867
3,115
When does it backfire? Cold, hot, idle, light acceleration, hard acceleration? Is it backfiring through the carb? exhaust?
Clone TIE Pilot
3,859
2,611
Galaxy far far away
Likely its because the fuel mixture is lean, probably a vacuum leak somewhere. Also could be a broken intake valve spring.
83MonteCarloSS
153
254
Have you checked timing? It sounds like your base timing is good but what is the base timing? How much mechanical advance? How much vacuum advance?
