I've rode in a couple vehicles with airbags and couldn't believe somebody would install that on their car. The ride quality was awful, it hurts your back when you lower it, the air tanks run out after only lifting and lowering it a couple times, you cant ride with it lowered because it needs air in the lines to have any suspension at all, and both cars had electric compressors that we had to shut off first if we wanted to talk to each other. Thats sound it makes when you lower it is annoying too.
With hydraulics you should only be replacing your batteries every few years. A street charger keeps them charged when you are driving. Accumulators are a must if your using stiff springs and poly paks will keep you from having to change o-rings so often.
