yesterday when I went to start my car the battery light flicked about 2 times. I had let the car warm up for about 10 minutes because it was about 20 degrees outside. Remember I just got done fixing the no start problem which was in the starter because of corrosion. I must have more corrosion somewhere right??? The battery light is indicating low voltage correct guys? Also I do have a evident coolant leak somewhere might be the start of an intake gasket or head gasket. Not to worry its winter now and plus I wanna start building a motor outside the engine this spring. If someone could though sum up how hard head gaskets are on these cars? I have done them before on front wheel drives. update though the car does squeal the internet says its prolly the tensioner or serpentine belt too being too tight?? Any ideas.
