I think my cam is .600+ lift. I don't know at what lift BTR believes that the vavle springs need to be changed every year, but mine is one step down from that.I wonder if you have the same cam I do- BTR on a Comp core View attachment 164598
Gotcha. I was just trying to guess how much steam my 468 is making.I think my cam is .600+ lift. I don't know at what lift BTR believes that the vavle springs need to be changed every year, but mine is one step down from that.
Can't recall the exact number, we did some horse tradin for the cnc time for the port work. I wrote the program to cut the offset push rod holes for his CNC 5 axis mill. I'd love to get the heads flowed one day. I spent a lot of time on the short turn radius and opening the "throat" below the vavle seats.Gotcha. I was just trying to guess how much steam my 468 is making.
How much did those heads set you back?
BooooooThe water pump application is a 82 to 85 4.3 V6 diesel, only available in cast iron.
This is the GMB reverse rotation water pump I was refering to.The water pump application is a 82 to 85 4.3 V6 diesel, only available in cast iron. I used a Ford 351 truck crank pulley drilled to the Olds crank bolt pattern.
