I have some thing, I think some of you would like to see. I am in the process of changing my rearend from a 7.5 to a 8.5. I blocked up the rear of the car to remove the rearend. While I was under the car I noticed a oil leak. I thought the rear cover was leaking a little bit, but once I took a better look at it. I found the oil was coming from the tube where it goes into the pumpkin. I scraped around and found painted silicone and a bent axel tube. I knew the left rear of the car had been recked before I got it. The last owner had fixed the left quarter panel very poorly . But wow what was he thinking when he hid the axel tube. Good thing I decided to upgrade the rearend first on my car. I was going to box the factory lower control arms, but decided against it. I think with the bigger sway bar it will stiffen the control arms up. When I start making real power I will do some bracing up back there and upgrade the control arms. It will be just fine with 175 horsepower! I have a set of good aluminum brake drums off my 7.5 and a set of new steel ones. Not sure which one I want to use. What do you guy's think of this? Should I go with aluminum or new steel drums?
My 8.5
