Want to put in a floor shifter on my 85 with bench seats, what shifters will work with 4 speed trans and full length headers? Might also switch to buckets eventually, but for now I'm hoping to find something that will work with a bench
I used a B&M Megashifter, too. It works great with my 200-4R. Since it is a cable type, you can mount it as far forward as you want as long as it doesn't hit the dash. When you switch to buckets, you could move it back. If you are going to beat in it like I do, use some big fender washers on both sides and use bolts and nuts when mounting it instead of sheet metal screws. You will have to get a couple of longer pan bolts to hook it up though because the originals are not long enough with the mounting bracket for the cable on the trans. Keep the cable away from the headers or shield it!
