Best octane boost?
ZZ4CutlaSS
411
95
Minnesota
The highest octane fuel I can buy locally is only 91. My ZZ4 requires 92 or better. So im wondering what everyone has had the best luck with. I have been using Lucas Octane boost but dont really notice a difference. Good thing is im not pinging now but had to back the timing 2 degrees.
CHRIS.O
1,432
36
MI
I don't really use any octane booster. One thing I've noticed about the ones I've sold or seen in stores is that when they say they up the octane by one or two points or however many is that its tenths of a point. So going from 91 to 91.2 doesn't really seem like justification for spending 8 bucks. I am sure there may be better ones I am unaware of so hopefully you can find one. I know you said thats the highest octane you can get locally. Have you checked at the race tracks? Or online to see where any race fuels are sold. You would be better off dumping a gallon of 104 into 5 gallons of 91 or do the math on the ratio and you can figure it out. Of course some of the race fuel is leaded so steer clear if you have sensors that can't handle lead. Good luck.
chstonebraker
107
my buddy travis normall goes out and buys 5 gallons of 112 racing fuel and puts like a gallon of it in per tank and he has a camaro so the tank isnt that big... big difference and car runs cooler and much better.
454cutlass
315
24
mass
I have used toluene in the past. I belive its 116 octane. Its found in paint supply stores with all the other paint thinners. You can also look up torco racing fuel
pencero
1,466
25
38
Ind.
All octane boosters are made up of a chemical which is illegal to distribute to individual consumers so they are 'cut' with less hostile chemicals and made under different brand names generally using the same or similar formulas. I know this from working at a chemical plant for a short time. I don't recall the name of the chemical but it's methyl- something or other and you should really just buy the cheapest octane booster because they're all a scam selling you pretty much the same chemical at a different price and all you're really buying is their name and the fancy design on their bottle. Just get the cheapest one, and as a matter of fact if you see a half size bottle of 'motorcycle octane booster' and its cheaper just get that b/c its really just the same thing so why pay more money for it either way?
It sounds like they are using really crappy gas out your way, you might want to look into something called 'sta-bil' if your car is running badly on e10 / e15 or blend gasoline. You could be treating symptoms to the wrong diagnoses
Smokes442
Jan 20, 2012
65
How were you mixing it? Did it work with no ill effects?
Smokes442
Jan 20, 2012
65
What is your set-up, I'm getting away with 91 octane in my 406, the timings at 35*, the compression is 10.4 with iron eagles, my Dynamic #s are like 8.0s with the cam i'm running.
FE3X CLONE
2,714
52
48
Ohio
Plain and simple, octane boosters are just a gimick for taking your money. They do not work. At least not like they advertise.
As mentioned, they are not increasing your octane by full points (as they lead you to believe) but rather tenths of a point. If you are running 93 octane and dump in some 104+ octane booster you'll be lucky to get 93.2 octane or similar.
Clone TIE Pilot
3,906
2,690
Galaxy far far away
The only good octane booster is a proper quench setup in your engine.
