So currently I have a brand new SBC 350, .030 over, 882 series 194 heads, stock bottom end, Eddelbrock performer intake and Holley 600 cfm carb. All this hooked into a th350 that WAS bolted to the Buick 3.8L v6 and the rear gears are 2.3:1.
Im fairly set on reducing the chamber size to 64cc down from 76cc, BUT would it be better to get some aluminum heads and spend a thousand dollars or get a set of Vortecs and save a bit?
For the rest of the drivetrain, it's a dog. Engines maxes at 3k RPM with the pedal slammed and accelerates slower than a Honda civic. How do I make that automatic faster without compromising the drivability on the freeway? (aside from rear gears, I know that will have to change.)
If anyone is running this please let me know how you did it and what worked best.
