Er.. Temp sensors. I could run both oil senders but eh. There was only the one. I bet it's the same situation for the coolant temp though.
I know, right, priorities! Gotta have decent tunes. Hey this is the first thing we all did back in the day, right?
The glue that made this so easy. Two wiring harnesses via eBay. One for the radio, one for installing an aftermarket radio in the Cutlass. Hook the ends, solder, and shrink wrap. Maybe 20 minutes doing that, probably saved hours up inside the dash trying to butt-splice and hack things up that way. Do it this way, trust me. Verify that the color codes are the same. These were identical, but that may not always be the case.
The plug in the car is actually 3 plugs. Don't panic when you pull them out and let them flop, they are keyed (bottom edge) so they'll only go into the new harness one way.
I had to take these brackets off the original radio and use them on the Pioneer. They're 30yo plastic and brittle, one hole broke on me trying to fit it up. luckily it didn't matter much. The cuts on my hand are from the #%^@#$ trim piece that didn't want to come off.
All done. No cutting, hacking, or anything. Fits right in. Find the right replacement or at least get a single-DIN and a bracket kit. Don't cut up the dash to fit a 2-DIN unit unless you're really good at making it not look like garbage. Sounds excellent. I have a set of Pioneer 4x10's laying around here somewhere that I've had since '89. I should see if they're any better than the stock speakers lol. Not going to put an amp and sub and all that garbage in, its not that important that I lose any more of my hearing.
Lucky for me, and you probably can't tell.... The bottom left corner of the trim plate on the radio broke off. I super glued it back on, but you can't even see it. I was prepared to sand it and paint it, but eh, nobody knows. Well, erm, you know what I mean.
