If your looking for full length then I would use the Hooker 2455's to save money. They do make headers for BBC swap into Gbodies but they are expensive. The 2455's are designed for late 60s early 70s Abodies like the chevelle but I have heard they work with minor tweaking. Il be getting these for my BBC swap.
Sanderson makes a BB-3 short, but not "block huggers". Search them on Ebay. They're not balls out, or tuned length, but headers. Watch the coating vrs the pics.
I have used the Hooker 2241 on a couple builds and they are not cheap but they install easily since they have 3 slip tubes and they have good ground clearance and spark plug access there is no tweaking to install since they were designed for this swap and I think you can remove the starter with the header in, just by removing the two rear slip tubes.
Hedmen also makes a full length header for this swap but I have never used them so I don't know how well they fit and same goes for the Hooker A-Body headers 2455.
I currently run Lemons Headers on my engine now since the shelf headers are too small for my application.
