What springs are you guys running? I have read the spring rate charts more than several times but I still cant decide what springs will work good but not overdo it. I have a bbb and was leaning toward the f-body springs with the low 700 spring rate which I think will work good. My concern is that I want a drop also(not getting drop spindles) so if I cut a half coil or whatnot my spring rate will increase but it may increase the rate to an unbearable stiff ride since the rate is already 700. Will the high rate S-10 springs put the ride quality back at stock since the big block is in there?
