big block mounts,
rodney ford
6
4
58
hello everyone, new to the g bodies and i bought a tubbed 1980 cutlass, i am installing a big block chevy and need to know what frame mount and motor mounts to get, is there a part number for the crossmember for the headers? thanks!!
Hilarious a Ford is putting a Chevy in his Oldsmobile.
The stock clamshell ones work if you are using stock type mounts. Otherwise like someone above stated the sbc ones are the same. If you don't already have headers the Hooker 2241 headers fit perfect!!!! Just minor trimming on the motor mount if using stock ones
You won't notice a difference between solid and stock ones ,not a big deal ,but 73-87 Chevy 4wd truck are the same as car ones probably 10$ a peice from the auto parts store ,you may have to do a little dinging on the oil pan if you use a truck pan ,still no big deal tho
