Before you do anything.
Double check that the engine is actually a pass. car 454 and not a 366, 427, or 454 tall deck.
After that, if it is a pass. car 454 the swap is easy.
If it is a tall deck I would pass on it.
There great for a track engine but on the street and highway you will not be happy at all.
The 454 goes in the same location as the SBC with the same mounts.
The driveshaft length has nothing to do with the engine placement.
if you are using the trans that is already in the car. The trans will be in the same exact location.
If the motorhome has a t400 in it or a 700r4 trans (they were avalible in 83) you will need to modify the crossmember and driveshaft.
There is also a truck t400 and a pass. car t400. Truck has a bolt on yoke the car a slip on.
If your handy you can get the Hooker 2455's to fit with very minor mods and save yourself a bunch of $$$
