ok so here it goes. my new high torque mini starter will not work on my block. heres the issue. i, running a 153 tooth flywheel because i have to in order to fit the factory bellhousing. only problem is my block only has the staggered bolt pattern for the 168 tooth flywheel. so what do i do. csr lists a 153 tooth starter with staggered patter but the thing runs $340 and is a 3 month delivery date. now they do sell the mounting block for their starter as a replacement part. their starter appears to be a standard tilton gear reduction mini starter. my starter is a tilton style. perhaps i could use their mounting block on my starter as it is only $72
mounting block
http://www.summitracing.com/parts/CSI-110SBP/?rtype=10
csr starter
http://www.summitracing.com/parts/CSI-100PSBP/?rtype=10
my starter
http://www.cfrperformance.com/CHEVY_SMA ... 07-pbk.htm
mounting block
csr starter
my starter
