When I went to the track this past wednesday, I volunteered to race in street class bracket racing called "Whoop *ss Wednesday". Long story short, got into the final race against an older guy in a mustang. He caught me wiping down my motor because I had a small trans leaks and he starts bitching at me saying I was making a mess all over the track when none of the officials said anything to me (the same officials who had been rooting me on all night). He then goes and rats me out to one of them and they were forced to inspect me on the spot. We found that I ripped my rear intake gasket, so they had to DQ me, but gave me a free pass next time I go out so I don't have to pay to get in. Then they escorted mr. douchebag mustang owner off the track and off the property.
So now I'm making mods to get more performance out of my motor. IE better carburetor than a 600 edelbrock, swapping in a ford 9 rear end, and slicks.
The help I need right now is in a carb recommendation.
I'm at the point where my engine is making more power and the carb is not supplying enough. Now that my malibu has turned more into a street/strip car, I'm in need of more on the top end instead of just cruising power. I'm having to make shifts in the 6000-6500 range (within cam operating rpms) to compensate for the gear drop from first to second.
Below is the drivetrain setup:
Engine
- 350 with .010 bore
- Lunati Voodoo 60103 (.489/.504 lift. 227/233 dur. @ .050, 110 LSA)
- 9.4 : 1 CR
- Iron heads, 2.02/1.60 valved, slight port work, 1.6 rockers
- RPM Air Gap intake
- Flowtech full length heads
Drivetrain
- 700r4 fully rebuilt (copycat monster transmissions)
- 2500 stall
- Currently 3.73 monte ss rear end
- In the middle of ford 9 rear swap
I've narrowed down my choices of carburetor to a Holley 650 double pumper, or Holley 700 vacuum secondary. Looking for input and any other recommendations.
Engine
- 9.4 : 1 CR
Drivetrain
- 2500 stall
