I am a fan of doing the lowers and double adjustable uppers. There is no downside. Set your pinion angle so that the car plants the tires instead of lifting the rear and unloading the tires. Somebody on here just posted on here tonight about picking up an 8.5 and saying that they were going to have the support cover for there 7.5 to sell. You are a long way from needing a ford 9. A ford 9 will soak up more power that assuming the same traction would slow your time a little and eat up a little more fuel. Drag radials would help but are not needed yet. Do you have an air bag for your right rear spring? It will help pre load the suspension for best traction. ie two even flat black marks from a burnout that does not involve brakes.
I bought my GN new. I remember going the GS Nationals back in 88 the first time I had ever been to a dragstrip. Got to do some test and tune passes. Car was box stock and I had no idea what I was doing. But by the end of the day with a little coaching I ran a couple 13.9s & 14.0s at 99mph. Box stock suspension and little 215/65/15 eagle GTs. 23 years ago and I still like the dragstrip. Pat you probably should have stayed out. :lol:
