BLAZER BRAKE UPGRADE
It will be, but IMO the difference is negligible. The caliper slides anyway, I seriously doubt you'd run out of travel there. The only other thing is whether there are chanfers or bevels that won't play nice, but that's easy enough to check.
Agreed & my main concern. Figured, If there were 'shims' readily available, it's an easy was to eliminate a possible issue that may or may not exist. I worked w/Tobin on the C10 big brake kit modifying & testing various spindles to make sure things worked as intended. I'll e-mail him just to see what he has/thinks.
why not just get the dust shei;ds i ordered them on amazon and still run them on my vette brakes now
Didn't want to order them not knowing if they would/wouldn't work w/the big-brake change. with that info now shared, I might do the same.
right on, all sources including kore 3 say they don't work, we literally just bent em back a shade and they work just fine with the base c6 vette brakes, if you run the c6 z06 the rotors will run a bit past it.
