clean8485 said:Judging from what I can see in your rear brake photo, you may have problems with the backing plate for the rear brakes. GM designed a setup for these cars and the earlier S10 trucks, where the wheel cylinder is clipped onto the rear backing plate, not bolted on, as in most cars. If the car was used in an area where corrosion is an issue, then the backing plates would start to rot out, and as they did, then the wheel cylinder would get loose on the backing plate, and eventually "spin" or "twist", the way it appears in your photo. GM did issue a recall for backing plate and wheel cylinder replacement on these vehicles, but that was many years ago, and I'm not sure that it applies anymore. I did a number of these recalls when I worked at the dealer back in the day. Another problem that you usually run into when you have to do this type of repair, is that brake lines are rotting out, and need to be replaced, and the same thing with the rear parking brake cables. GM only covered the backing plates and wheel cylinders. They would cover brake shoe replacement IF the wheel cylinders had leaked, and contaminated the brake friction material, but that was pretty much it. If the wheel cylinders are loose in the backing plates of your Cutlass Cruiser, then at the very least, I'd look at replacing the backing plates and wheel cylinders. I have seen replacement backing plates available from the aftermarket, and many of them are of a 2 piece design, so that you can replace the backing plate, without taking the rear axle shafts out of the axle. Hope it all works out for you. Good luck.
O. D. Showtime said:I know I posted once already...but the twin to your car is sitting in a wrecker here....lol
classic gbody said:I had an 83 Cruiser. It was bought new by my parents and I got the car after my sister wrecked it in the front when the car was 15 years old. Thats why the front clip is a different color. I drove it for another 5 years after that. It was stolen from me and recovered. I fixed it again and drove it another 2 years then drove it to the junk yard after 260,000 miles. The Ohio rust was too severe to save it. I would love to get another some day.
These pics were taken back around 2005
