Blower box sealer
JD1964
384
521
We’re moving kind of slow on the LT1 swap but still moving nonetheless. The front clip is off and currently no engine or trans in car. We cut away part of the AC blower box since the car will be AC delete but still retain heat. We made an aluminum panel to cover the hole and attached with internal brackets and screws so it can be removable for heater core change when needed.
To seal the small gaps around the edge of the panel we’re considering using duct sealer like HVAC or electricians use. It has a flashpoint of 310 degrees. Is that flashpoint safe for under hood use in this manner? It will probably be at least 8” away from any header piping.
3M strip caulk might work
Used it to seal up my heater box
Reactions: Olds G's
I've also used 3M strip caulk
I might take a look at the 3M strip caulk too. The idea is to have something that is easily removable and can also withstand the under hood heat with minimal risk of igniting.
