blower motor not shutting off
DETROITBOY27
Apr 3, 2008
52
houston tx
when the car is running, the blower motor / fan for the heater/ac keeps running even when it is in the off position. I can adjust it from high to low. When I had the vehicel checked out the mechanic said I needed a new control unit. So I bought a new one and it did not fix it. Any ideas?
BACKSLAP
22
blower resistor itself, unplug it first, then check to see if the fan motor itself is shorted internally.
try these things, dont replace parts until u check your voltages bro
dan2286
2,233
4
Cleveland, Ohio
There also might be a relay, depending on what year car it is, make sure that is good also.
BILL DEMMER
31
is it running at a very low speed? if so, that is the way it was designed to work, to keep exhaust gases from building up inside the vehicle.
bill
