body mount bolts
Silent viewer
1,445
142
I am getting close to putting the body back on the new frame on my 84 regal, its been apart for 4 or 5 years now. I do not even know where the old bolts have ended up, so I cant take them in. I can buy a kit for 40 off of ebay but I cant help but think that I can get them cheaper. the company I work for get discounts through the fastner companies around town so if I can save a few bucks then sweet. does anyone happen to know the length, thread and bolt type for body mounts?
I saved this when I was doing my body off...$40 isn't a bad price cause metric bolts are way over priced
Position 1 uses GM P/N 10049638 (sold ea., 2 needed). Bolt is 12 X 1.75 X 95mm long.
95mm is not common so you have to use 100mm.
Position 3 uses GM P/N 14085301 (sold by pkgs. of 5, 2 needed). Bolt is 10 X 1.5 X 55mm long. Also need two nuts.
Position 2, 4, 6, 7 uses GM P/N 3524497 (sold by pkgs. of 5, 8 needed). Bolts are 10 X 1.5 X 80mm long.
When I put new in body bushing I got new bolts from gbodyparts.com. I think they were around $40
I got mine from the local GM dealer at the time. It also pays to know the parts man. :wink:
Pontiacgp is right, they're sold in multiples.
Good info here. Posting just so I remember the thread, lol. Thanks you.
Here's the map. Couldn't find my part number list for the bolts but any GM dealer can. ...
Position 1 uses GM P/N 10049638 (2 needed). Bolt is 12 X 1.75 X 95mm long. 95mm is not common so you have to use 100mm.
Position 3 uses GM P/N 14085301 (2 needed). Bolt is 10 X 1.5 X 55mm long. Also need two nuts.
Position 2, 4, 6, 7 uses GM P/N 3524497 (8 needed). Bolts are 10 X 1.5 X 80mm long.
:arrow: :arrow: :arrow: :wink:
Scott,
Pontiacgp (Steve) indicated the GM part #'s for the bolts earlier in the thread and what bolts and sizes are used in each position.
ssbrewskyaz said:
Well there you go. My dad always used to say "two heads are thicker than one".
:arrow: :arrow: :arrow: 😳
if it will make you feel better I can delete that post..... :mrgreen:
