Burnhard said:
Thanks for the reply. If you were to make a list to make your car handle better what would you start with? Street car on a budget best bang for the $$$$? What mods and why you would make them?
This is just one man's opinion, but you asked, so here's my plan to get the most impact for least $$ on a street driver. I will assume things like springs, bushings, body mounts, ball joints, steering linkage etc. are all in good shape. If not, fix the weak parts first before any mods.
1) Shock absorbers. Shocks affect virtually every aspect of vehicle dynamics, including wheel control over road irregularities, roll control, brake dive, acceleration squat, as well as the transitions from acceleration to braking, corner entry and exit.
Buy the best shocks your budget will allow. Popular brands are Bilstein, Edelbrock and KYB among others.
2) Roll control. Roll control allows you the maximum use of the contact patch of all 4 tires by minimizing the weight transfer to the outside tires in a corner, as well as minimizing the resultant camber change at the front tires. The stock F41 bars are a decent cheap upgrade for a non-F41 car. Swap the front bar's rubber bushings for aftermarket urethane bushings and use hard end link bushings. Mount the rear bar as far forward as possible without forcefully wedging it in the control arms and causing a bind. The resulting shorter arm length will make the bar more effective. Aftermarket larger bars are even better, but much more expensive, If you do go aftermarket, keep the front / rear size ratios similar to the F41 setup, with maybe a little more bias toward the rear. When I used to autocross, I would run a stock front bar with an F41 rear bar, since I wanted the car to be loose so I could toss the rear end at will, but that kind of setup could get you in trouble at higher speeds.
3) Tires and wheels. Run as much tire as you can, especially on the front, and as wide of a wheel as possible. 7 inches is the absolute minimum wheel width to consider; 8 is even better. Given a choice, run the lightest weight wheel possible.
4) Camber curve. G-bodies, like most American sedans, have a horrible camber curve. Ideally, a tall spindle setup like Global West or Hotchkiss helps keep the front tires flat on the pavement, but again speed costs money. In the absence of $$, get your front end aligned to performance specs, i.e. Camber as close to vertical as possible, maximum attainable positive caster and a minimum of toe-in.
5) Structure. Structural reinforcements have been discussed in this forum at length, so no need to rehash. By themselves, structural reinforcement or bracing does absolutely nothing to improve handling.
But, by reducing the chassis flex and/or twist while cornering, the suspension is better able to do its job. At the very least, find a set of F41 bars or a Grand Prix bar for the front and tie the ends of the frame rails together front and rear with some fabricated tubing.
I could go on a lot longer, but this will keep you busy for a while. Reply if any questions.
Bill
