bouncy bouncy hood
TRX
31
4
8
Central Arkansas
On my '80 Malibu, I have the latch and side stops adjusted so my hood sits evenly with the fenders and front fascia when closed. But going down the road, the front corners of the hood bounce about noticeably; on a rough road, maybe 3/4 inch. And on the freeway, the corners will lift a quarter inch or so.
Nothing looks obviously fatigue-cracked underneath. Is this normal with a G-body, or what?
Just being curious-are you talking about a steel hood? I used to have a fiberglass hood on my Monte Carlo, which would act like what you're describing.
I would double check your adjustment - with the hood shut you shouldn't get any movement pressing on the corners. If the hood is lifting on the freeway the latch needs to be adjusted tighter.
Reactions: pontiacgp
It's the original steel hood, as far as I can tell.
Cranking the latch down until the middle of the hood is below the fascia doesn't help; the corners still bounce up and down.
Everything is adjusted level with the car sitting in the driveway; the corner bumpers support the corners so they don't move down at all. Just up.
I have never seen this issue with a steel hood but hood pins or locks would definitely control the upward movement.
my old cutlass was pretty bad. I think it was the adhesive blobs which bonds the underhood bracing to the hood working loose. That and stiff hood hinges didn't help. I too did the 4x4 in the middle of the hood to try and load more tension in the corners against the adjustors trick. When I swapped the hoods the problem went away
