Brake conversion???
If your going to do the effort of swapping brakes. It's easier to do 98-04 blazer front spindle/ front brakes then 98-02 camaro rear discs. Then if you decided down the road you want to go even bigger you can get c5/c6 brakes with little mods. Blazer brakes can use 15 inch -up wheels. Camaro brakes require 16inch-up wheels.Vette brakes 17inch-up wheels. Riviera, Eldorado brake proportioning valve is 4wheel disc and bolts right up to all gbodys and same with there master cylinder will work with any year gbody or gm brake booster.
Reactions: Streetbu
