Rear brake kit for ford 9 inch conversion on an 87 cuttyIs this a trick question?
I've had good luck with Powerstop rotor and pad kits from Rock Auto on my daily. They are China which I'm not crazy about but good luck finding USA rotors. EBC is made in the United Kingdom. I ran a set of their yellow pads on my daily and that was the wrong pad to choose (my fault) as they had a short life (stopped great though). When I did the Blazer brake swap on my GP I went with Powerstop.
Thx man but i was meaning a whole brake kit. Calipers, rotors, pads, lines,.... the entire setupI've had good luck with Powerstop rotor and pad kits from Rock Auto on my daily. They are China which I'm not crazy about but good luck finding USA rotors. EBC is made in the United Kingdom. I ran a set of their yellow pads on my daily and that was the wrong pad to choose (my fault) as they had a short life (stopped great though). When I did the Blazer brake swap on my GP I went with Powerstop.
Ok so what caliper kit is the best bang for ur buckI don't suggest any cross drilled rotor, they are not needed, they crack and you get less braking surface.
What's wrong with stock calipers.
Rear brakes have drum brakes. Dont want those.What's wrong with stock calipers.
Not sure yet. Ordering new moser 9inch rear soon. Thats y im searching for new brake kitsdo you have small or large axle bearings
