FE3X CLONE said:
mebe007 said:
can you get these fittings at the autoparts store? i need the same adapters to install my line lock
You can buy just the fitting itself or a small length of repair tubing and cut the fitting off.
G-body's didn't use metric threaded brake lines.
As for size, a lot of times you can look at the color of the fitting(s). They color them differently to help differentiate the different sizes.
Or you can get an inverted flare-to-NPT fitting like this:
http://www.speedwaymotors.com/Male-Inve ... 24770.html
The colored fittings are adpater fittings.
Example: putting a tube nut on 3/16" brake line but has the thread size of a 3/8" brake line
Your standard tube nuts will be either natural steel or brass
mebe007 said:
what i need are the 1/8 not adapters for the line lock. i got my line lock used with no fittings. so i need to know what thread size the front brake line is (rear port on master) so i can get the 1/8" adapter to fit the line and line lock and get one for the other side and get a small piece of line from the master to the line lock
I believe you need a 1/4" inverted flare - 1/8" NPT adapter. I can check our line lock kit tomorrow to verify.
