I have a wife and 2 daughter's 4 Cutlasses and the square body crew I was lucky I had that!Clutch.....only a $1 bill?.....talk about being cheap...😀
. Most certainly, the traditional will grab first and the car will pull to that side in a hard brake. I had an experience around the time of that Bendix letter I gave the link for when the car did a 180 into the incoming lane avoiding a deer in the wee hours of the morning. Fortunately, there was no one else on the road, but I don't doubt that kind of thing was happening. Not checking the grooves might save money short term, but it would open them up to a nasty product liability class action lawsuit.
Beer willfront brakes will not put a car into a spin even if one side is pulling
Well today I put the new Master and the pipes between the master and the proportionig valve are not the same, the front pipe are more reduce and the rear are more big......sorry for my english. ...
I'm not sure exactly what you mean by "pipes". The brake lines should all be the same 3/16 inch diameter. Otherwise, someone has changed the stock hydraulics and modified your brake system. (Maybe it is easier to find metric brake lines in Chile?) However, the fitting nuts can be different sizes. That was probably done on the assembly line so the workers didn't put the wrong brake line in the wrong place. Changing the fittings and reflaring the lines is no big deal, but if the brake lines are different diameters, you may have a problem.
Sorry I talk about the fitting nuts.....are different...
Yea like I said I put used lines in mine for a factory look. By the way all 4 of my Cutlasses have the same setup 2 79s the 78 and the 87 all the same thing so if you don't want to make lines go to a junk yard and get them off of any G-BODY and put them in your car I'll see if I have a picif you can get the nuts you need do you have a flaring tool you can use?. It may be easier for you to get new lines
