A home made system using the factory cables from the Camaro due to its ends. Original cable bracket cut and bent to fit using the drv seatbelt bolt as the attaching point. Work great. the cables ends are from all star performance. Have to use the brackets to move the shocks out at the bottom they will hit the calipers and won't bolt into place. I used a tube spacer cut to size to install the yellow bounce pads that are from a GMC Pickup. Th e-brake holder is from the camaro system that I cut to fit the SS housing and it bolts to the original bounce slot thru the tubing holding the yellow bounce cup all in place. It worked out perfect as to fit and functions to prevent the calipers from hitting the frame. Also the e-brake cables have to be secured to the tunnel with clamps or they will hit the drive shaft. I cut everything, put in place and tehn tookk out to paint and detail, then final install. View attachment 160930 View attachment 160931 View attachment 160929 at.
thanks, I', looking to see what I'm going to use for the rear brake conversion. I was planning to use the Seville brakes but I like the look of the set up you have. I already have the F body handbrake that is very similar except the handle mechanism adjusts the cable. It looks like the rear cables would need to be changed cause currently the F body cables fit the drum brakes on my 8.2" rear.
