'Talked to my machine guy who did the crank and rods, said that its common on olds and pontiac motors for the chain to be loose.'
Can't speak for Olds, although others have, this is wrong for Pontiac also. Sound like a shoddy shop.
You can get .005 under timing chain sets for Pontiac to compensate for wear and/or align bore.
A align bore matches all the bores up, you can't assume it centers off the front hole. A shorter chain could be needed.
I bought a "little Old man" LeMans that motor siezed right after I bought it. Turn out in it's pass the timing set lost a few nylon teeth. It appeared that the set had been replaced but the pan was never cleaned out, dam flat-rate techs.
Anyway, my buddy stops over and I am eager to show off my baby so I crank her up. About 15 seconds in, death noises.
Pulled the pan, found nylon all up in the pickup screen. The screen was totally sucked up and pulled away alittle at the edge. A tiny peice of nylon had gotten threw, wedged in the oil pump gears, locking the pump. It stopped so abruptly that it sheared the tang off the pump drive from the distributor. So much for my "new" car. 😳
