Brands of replacement gas tanks?
My 88 monte burps and kicks the pump off if i filled at full speed like Turna said. Its a stock tank i assume. The vent 565 referenced is the fix as far as I know.
It's all ready to go in tomorrow
The insulator straps could be a 1/2 inch or so longer IMO, but for installation sake, the velcro holds well enough
Dixie finally got them in, waited over a month for them
Anyone know the sizes of fuel line hose I need?
For the two here, and the metal chassis line to the fuel pump inlet?
The old one wasn't necessarily bad, but looking through the sending unit shows it wasn't exactly good either
This tanks been out once before, but apparently it never had insulators, or metal spacers on the front bolts
Tank showed up with the filler neck outside the box, but apparently it's supposed to be like that (slowclap for FedEx)
Once the DMV renews the registration, I can drive it down to the station and see how it fills
If I have to come back and add the vent, so be it
I'm running the spectra,gm 515{14091486} i did the external filler neck-tank mod and it didn't click on me this morning.
I'm stuck on reinstallation
Between the new tank, new straps, and new insulators, the ends just won't meet
I'm off to Home Depot in search of longer bolts
longer bolts do help for sure.i put pressure on my tank with transmission jack to help.as stated before throwing a universal diff vent on the unused sender hose is cheap insurance.
Well it's in
The secret is a jack, stands, and great patience
Also your gonna wanna hit up Home Depot for some M10x1.5 bolts
I went for 95mm, a little shorter would do fine
With the new straps and insulators, it's tight with no play
Gauge seems fairly accurate too
6-9 gallons got it nearly on 1/2
I did have to tweak the filler neck a touch to clear the plate, I hope that doesn't cause a leak
I force filled it from the gas can with no problems, soon I'll get to try it at the pumps
Update, tested at the pumps for the first time
Nearly empty and the first gallon went flying everywhere
I'm just gonna add the vent
Can I tee in from the existing vent hose, or do I have to drill into the sender itself?
Of course I bought the 2 port model, replacing like for like
Maybe best practice for the future is just to automatically buy the 3 port model, and just vent it with the spare port
