Well I just took the
H/O out for a shakedown run.............
Had some success and 2 failures.
Of course after redoing all the gauges the tach decides to play silly games and is so eratic...
![Doh :doh: :doh:](https://cdn-0.gbodyforum.com/oldsmilies/doh.gif)
![BLAM :blam: :blam:](https://cdn-0.gbodyforum.com/oldsmilies/BLAM.gif)
....so that needs addressed.
All was well when all of a sudden the temp gauge went high and had to put the car away. New thermostat seemed to be okay but
when I got back to the shop, the bottom radiator hose was a lot cooler to the touch...............so I'm pulling the thermostat to check.
And finally I nstalled the Shift Kit in the transmission from Trans Go and wow does that kit hit hard......
![Itchy Scratchy :itchy: :itchy:](https://cdn-0.gbodyforum.com/oldsmilies/itchy-scratchy.gif)
.....and it stays in the high
rpm band and then bang.....................yes, it barked the tires...............
I'm not sure id this is adjustable and if not I may pull the shift kit out..............
Overall the new brakes worked great,
👍the ride was superb with new shocks.
😎 I put gas in the new tank with no issues.
The steering seems to be very light...............very little road feel. May just be the nature of the beast. I'll have to check air pressures.
The rebuilt QJet worked great........
😎👍......the LED lights in the dash all seem to work well.
Shifter was okay.........with new cable..........may need to tweak the adjustment just a bit to get fully in low gear.
So as the
H/O is out in the garage puking her old antifreeze out...........I'll wait for a cooldown and order a failsafe thermostat.
Got a $10 off any part $20 or more at OReillys so I spent that coupon today. New windshield washer pump.
Still have to figure out why oil pressure gauge reads pegged at over 60.
Overall after 3 months of work, and missing a lot fo those days due to health reasons, I'm ok.....I am not the one who has the luck
to do it once and done. That's why it's my hobby and not my career.
