BUICK 350 INTO MONTE CARLO
alrobjr
23
Can any one tell me the part numbers to motor mounts and frame pads .I am installing a buick 350 in a 1981 monte carlo that had a 231 v6 and I need help on buying the correct parts for the swap. :?:
I believe you use the V6 mounts.
That's right.
The Buick 350 will drop right in on the stock mounts, and all the accessories from the front the the 231 V6 will bolt up to the 350.
i think so. the 455 will sit way to high in the engine compartment. the early a bodies used a really low sitting cast frame mount to compensate for the height. im not 100% sure .
