BUICK Buick v6 egr block off plate
CrammerGram69
437
143
SW, Michigan
Does anybody know of a site out there with some egr delete plates? 2bbl. I'd like to only spend about $30. I am open to getting a used one.
MrSony
6,831
6,741
Des Moines, Iowa
If you have the tools, make your own out of plate steel.
nycutlass
591
152
NY
use the gasket to make your own plate super easy to make
MrSony
6,831
6,741
Des Moines, Iowa
Or find an intake without egr. Kind of an expensive workaround. Otherwise, use some thick stuff. There's exhaust pressure there. Sheet metal wont work. has to be at least 1/8".
CrammerGram69
437
143
SW, Michigan
I do yes. I wouldn't know how thick it would need to be.
CrammerGram69
437
143
SW, Michigan
Never seen one before. Lmk if you find one i can readily buy. More interested in that
nycutlass
591
152
NY
3/16 is more than enough. or just cut the head off the egr you have now and fill in the hole with washers and weld it all in
CrammerGram69
437
143
SW, Michigan
I'm curious could i still put the egr on and just cap it?
MrSony
6,831
6,741
Des Moines, Iowa
the egr really doesnt affect anything that much, it's just a vacuum line. you can just cap the spot where it goes vacuum wise.
