Does anybody know of a site out there with some egr delete plates? 2bbl. I'd like to only spend about $30. I am open to getting a used one.
I do yes. I wouldn't know how thick it would need to be.If you have the tools, make your own out of plate steel.
Never seen one before. Lmk if you find one i can readily buy. More interested in thatOr find an intake without egr. Kind of an expensive workaround. Otherwise, use some thick stuff. There's exhaust pressure there. Sheet metal wont work. has to be at least 1/8".
3/16 is more than enough. or just cut the head off the egr you have now and fill in the hole with washers and weld it all inI do yes. I wouldn't know how thick it would need to be.
I'm curious could i still put the egr on and just cap it?3/16 is more than enough. or just cut the head off the egr you have now and fill in the hole with washers and weld it all in
the egr really doesnt affect anything that much, it's just a vacuum line. you can just cap the spot where it goes vacuum wise.I'm curious could i still put the egr on and just cap it?
