build pictures
Man, you did a hell of a job on that car. I love those rims and the fire on the valve covers and air cleaner. This build is sick man. Looks great!
What size are the wheels?
Nice. Thanks for sharing the pics. What did you go with for the 383 build? I like the air gap manifold. Some day I want to get a turbo hood so I can go with one myself.
D
D
GM 4-bolt 1 PC rear main seal
Crankshaft Scat steel 383 crankshaft
Connecting rods GM 3.750 w/ARP 150,000 bolts
Pistons Speed Pro Hypereutectic flat top 9.5:1 comp ratio
Piston rings Mahle plasma moly piston rings
Camshaft Speed Pro hydraulic .480/.480 - 230/230 - 111 specs
Lifters Speed Pro hydraulic
Oil pump Melling high volume oil pump
Timing set Cloyes HD double roller timing set
Bearings Clevite/Mahle HP "tri-metal" rod & main bearings
Harmonic balancer GM externally balanced
vortec heads port and polished
Valves Stainless steel swirl polished 1.60 / 2.02
Springs Comp series valve springs .530 max lift
Push rods Elgin hardened push rods
Rockers GM 1.5 ratio rockers arms, balls & nuts
dual plane intake eldabrock port and polished
holley 650 4150
You sort of cloaned a GN less the engine, turbocharger, & wheels. It looks great. BTW I like the wheels you picked.
Great job, do you flip cars for a living or a hobby? I'd like to that for a living but you need a lot cash on hand $$$. I am in the middle of doing the same thing you did on the buick..Great Inspiration...
