Well, it died today. It's not terminal, but I found out why it won't run properly. It seems the old fuel filter let plenty of rust particles from the gas tank get by it, and they did a wonderful job on the carburetor. I guess not seeing a full tank of fuel in about 10 years has a way of forming rust. The carb is not full of rust, but it is bad enough that it seized the primary metering rod piston in it's bore. How did I know what was wrong? Well, here's my tip for the day: Fuel should not be coming out of the accelerator pump piston actuator rod's hole at idle, or any other time. It was and that could only mean that the needle and seat were stuck open and flooding the engine with fuel. It's gonna probably run me about $35 for the rebuild kit and carb cleaner, so it won't get done today. I'll probably have to wait until Monday before I can afford to do it. I will also be installing a filter on the carb as well as my clear plastic filter that I keep in the feed line. This way, the sediments will have a harder time getting to the carb. It's not ideal, but I figure it's an acceptable stop gap measure until I can come up with the cash to find and buy a new tank. Why not clean it out? I ran over a big rock backing up one day in around 1994 and the tank is in bad shape. It's lost about 4 gallons of capacity, and I just don't want to try to fix it.
