The exhaust is hung now, but not without an ordeal. I do not know why they call it an "Easy Out", because they are neither "easy" to use, nor do they result in actually getting the broken bolt "Out". No, it didn't work for me because, as usual, the drill bits A) Did not make the hole centered, B) Managed to get dull half way through the first one, and doing a second....forget it! So, I wound up with two dissimilar sized holes in two broken bolts that laughed at my attempts to remove them. What did I do? Well, after finding that my tap handle is missing and making a trip to Harbor Freight for a replacement, I tapped the holes I drilled with two dissimilar sized taps. Now, I have one 1/4-20 hole, and one 5/16-24 hole. Why those sizes? They were the only taps I had that were close in size to the holes. At least, however, I knew which size I needed to buy at the local Ace Hardware (5/16-24). So, I tapped them, worked my blacksmithing magic on the mounts with a vice and hammer, and got the tailpipes to hang at the same level. Success! It was together and theoretically operable...
Unfortunately, theory only becomes fact when the battery has enough juice to start the car. It didn't. So, I took out my battery charger that was smoking the other day when I forgot to disconnect it before starting the car. I plugged it in, and whaddya know? Smoke! Trash can time! I still had not started the car, so I figured I would jump it off the truck. Now, it is important to note that the car is stuck on the ramps until I can get it running, so the truck had to come to the car. One problem: It had rained several inches in the days prior to today and the ground was soggy. I didn't think it was soggy enough to bury my little truck to the axles in my front yard though! Yep, I wound up tearing up my previously envy-inducing lawn trying to get the truck out. I had to dig it out with a shovel, and it was a foot from the sidewalk. Needless to say, I didn't get to drive it tonight. Hopefully I can borrow another charger tomorrow as I doubt the swamp that was previously my lawn (that was previously a swamp before it was drained and developed...) will dry out enough by tomorrow to support a vehicle. In any case, I still have until Wednesday to wait for my 6x9 mounts, so I can't do much until then except maybe fix the rear defroster grid and tint the windows.
