I would like to bump my motor up some. My motor is a sbc 350 and has an eagle rotating assembly with 4.000 bore x 3.480 stroke and 882 heads (76cc combustion, 160cc intake, 1.94/1.5 valves...so stock. I have been planning on a set of aluminum heads, 70cc combustion chamber,180cc intake runner, 2.02/1.6 valve. I am also going to bump up cam and lifters, it will be a full roller setup. I would like to know how big of a cam I can go with before I have to start worrying about vacuum issues. I have power brakes still along with stock a/c and heat, just no cruise control at the moment but I intend to have it eventually. I was originally looking @ comp cams mother thumper. Other info on car, 84 cutlass 2dr, 700r-4(currently 1800 stall speed w/ 30-spline) & 8.5" w/ 3.73. Any and all opinions are appreciated.
Specs: RPM range: 1900-5600
Valve Timing: 0.006
Lobe separation: 107 degrees
Intake Center-Line: 102 degree
Duration: 283 int/303 exh
Duration @ .050" Lift: 227 int/241 exh
Valve Lift: 0.513 int/0.498 exh
Lobe Lift: 0.342 int/0.332 exh
*also I intended to run around a 9.1:1 compression ratio
Valve Timing: 0.006
